Old 08-09-2012, 08:16 AM
tomfl tomfl is offline
Default Specific info needed on 20' Sceptre hull
Considering picking up an older hull for a resto and am looking for some input on a 20' Sceptre hull, hoping some owners can fill me in.
What is the freeboard/gunnel height on these boats in the stern corners and then closer up by the helm?
Is repowering these hulls an issue considering the weight of a new 4-stroke in the 115hp-150hp range?
Lastly, does anyone have firsthand knowledge of this hull and a late 80's early 90's Grady 19 dual console that can offer a comparison between the two?
Old 08-10-2012, 01:30 PM
50 views and nuttin?
Surely someone out there has repowered a 20 sceptre with a small 4-stroke that can add some input??
Thanks guys
-T
Old 08-10-2012, 04:41 PM
I think it was your asking for the comparison to the grady that limited your chance of any answer.
The 20 Sceptre was a pretty rare bird so there may not be any 4 strokes on that boat . I have seen new 150 etecs on them, and i/o.
You might want to PM Strick and see what he is putting on his bracket Sceptre.
Old 08-10-2012, 06:30 PM
I have a Sceptre 20' with a 2002 Yamaha F100 four stroke.The boat is currently on its mooring but as soon as I get down to it I can get the info for you.It does not ride stern heavy at all,any water that does get aboard goes foward on it.
Old 08-10-2012, 06:53 PM
Freeboard at stern is 23" ...
Re-powering is a concern. Weight is the enemy of maximum performance. They only have a 7.5' beam and a sharp entry so buoyancy is not like some clumsier boats. The 20 is strong and nimble . Recent model re-powers I'd consider:
DI 2 strokes
90 (330 Lbs)and 115-130 Etecs (375-390 lbs)
115 Optimax (375-390 lbs)
115 Tohatsu (375-390 lbs)
4 strokes
90 - 140 Suzuki (345 - 421 lbs) the 140 Zuke is the biggest I'd go only due to its power to weight advantage.
Merc 115 lbs (400lbs)
Yamaha F115(400 lbs)
The lightest 150 hp 4 strokes are the new Mercs at 455lbs and that is simply 100 lbs to much.
Second hand, the Sceptre will ride much better than the Grady 19 DC - no comparison...
Old 08-10-2012, 07:34 PM
Ditto Terry.....
Old 08-10-2012, 09:55 PM
That's a good list Gillie. If one was going to consider the 140 Zuke at 421 lbs, you might want to also consider the 150-175-200 E-Tec, as they're only about another 10 lbs heavier. If you include the weight of 6 qts of oil for the 4 stroke, the difference is even less.
Old 08-11-2012, 12:19 AM
I can get some measurements for you. I am considering a 140 suzuki for mine but I am adding a very large flotation bracket on the back of the boat. I cant give you any info on the ride because I have never been in one but I am confident I will like it.
Old 08-11-2012, 01:32 AM
Good point, Denny.
I know those numbers are all dry weights and I didn't even consider the extra 10 lbs of oil
I was going to throw in the Etec 6 cyls but thought even the 140 was pushing it... But hey, csicknick has a 140 on his Seafari and drags 300 lb bft over the gunwale like "whats the big deal?" so I as I rethink this, a 25" transom goes a long way to maybe allowing more weight.... Nick's still sticking fish, right?
Drop us a line Nick, how'd the striper derby go???
Old 08-11-2012, 08:13 AM
I've been on Ebeach's restored Sceptre a couple times and he powered it with a 130hp Yamaha 2S. To me that engine is perfect on the the 20's in general. I don't believe Yamaha makes that engine any longer so you'd have to go used or stumble onto a leftover.
