Old 08-28-2012, 03:01 PM
Dilligaf Dilligaf is offline
Default coal tar epoxy vs interlux 2000e
which one should i use to coat my new gas tank. any difference in the prep work if there is any at all?
Old 08-28-2012, 07:45 PM
pelican pelican is offline
i use interprotect 2000e - nothing else
you need 2 colors - grey and white
this assures a full coverage - you want that coating approx 10mil thick - use a matchbook cover as a guide
prep:
clean with acetone - scuff sand,chemically etch prime,them coat it..
nothing will properly adhere to aluminum,without a chemical etch prime
Old 08-28-2012, 07:59 PM
prep:
What about Linus?
Sorry Line X.
Old 08-28-2012, 08:04 PM
What about Linus?
Sorry Line X.
why ?
seriously,why ?
epoxy products are waterproof - meaning,the aluminum is completley isolated from any moisture - read that as corrosion
now,i've seen and read of some backyard guys actually believing,if they fill the pinholes in a corroded tank,with marine tex,and then,wrap that corroded tank with fiberglass matting - using a polyester resin - common sense would tell us,this is a real bad idea,yes ?
i've seen a fuel tank coated with rhino liner - that coating failed,and failed miseribly...
sometimes,it's best not to try and reinvent the wheel - it's round and it rolls...
Old 08-28-2012, 08:31 PM
why ?
seriously,why ?
Line X is not Rhino crap. That`s why. Open your mind.
A very well respected builder uses something else.
And then we can talk about MMC.
The best thing about this site is the folks who care,
GFS
Old 08-28-2012, 08:51 PM
GFS
my mind is very open - allways willing to try new things - however,there's certain things i won't experiment with - one of them is fuel tank coatings,and the installation procedure i follow...i stick with what works,and what's accpetable to me,after all,if there's a problem with it - i gotta stand behind it...
just because a "well respected builder" uses it,doesn't make it a good idea,or the preferred method - i've seen plenty of "well respected builders" do some really stupid things - proline is a good example,i replaced a transom in an older proline - the core was CDX plywood stapled together,and pieced,stringers were the same material - not good huh ?
grady white is another - their cockpit deck hatches are supported by the fuel tanks - against codes - is that a good idea ? is that a good method ? their scuppers are under the waterline - depending on the load in the boat - no positive shut off - again,ABYC codes state that's wrong -is that a good method ?
get the point here ?
guys that are "in the buisness",like ol' don herman,and myself - see things in a different way than guys who are doing pojects in their backyards - don't read any disrespect into that,if you guys make a mistake,no big deal,you're gonna do it again,a follow a better procedure - "in the buisness",it's a little different - get the point ?
yep,i care - i hate to see people make a dumb move,i give "the voice of experience" - i try and save you a step - the "step" being,making a bad decision,that's gonna cause a problem down the line...
there's a great movie - pulp fiction - great line "a sewer rat may taste like pumpkin pie,i wouldn't know,'cause i would never eat the filthy motha *@#*er"
i'm open minded,but not that open minded...
Old 08-28-2012, 09:19 PM
get the poin
Nice.
Colors on display. Richard. You Suck. Go away please.
GFS
Old 08-28-2012, 09:26 PM
how do you "chemically etch prime" it first? is there a product i can buy that does this? recommendations?
Old 08-28-2012, 09:28 PM
i dont care really about costs i want the best so it lasts. my wallet is the one thats says "BAD MOTHAF&CKER"
Old 08-28-2012, 09:29 PM
i use west system etch - there's a few others on the market...
