Go Back   Classic SeaCraft Community > General Discussion > Boatbuildercentral.com
Old 10-02-2012, 02:51 PM
shine shine is offline
Moderator
Default fixing glass damage - plugging vents
this is a carry over from the repair I have to make to the side of my SC23.....
So now that I cant use the boat for while (motor was stolen :x ) its good time to get the jet ski damage fixed. I might sell the boat, but in any case I need to fix this now.
Beveled back the hole, filled with some epoxy putty before layering in a few layers of 6 oz cloth. Sand the cloth, add first pass of quick fair
epoxy is here
http://boatbuildercentral.com/produc...1#.UGs2blKBXTo
cloth is here
quickfair is here
http://boatbuildercentral.com/produc...1#.UGs2iVKBXTo
Old 10-02-2012, 03:44 PM
Would you sell the vents?
Thx,
GFS
Old 10-03-2012, 11:04 AM
Moderator
I would give them to you, if i had them
Vents were already closed in when I bought the hull, but the previous guy did not do a good job and the patch popped out when the jetskit hit the boat. Previous guys just put a little matt over the hole with some foam core backing!
Old 10-17-2012, 04:04 PM
Moderator
forgot to update. Its pretty well fixed, for now.
Sanded quickfair with 80/100 grit
rolled on a few coats of System Three highbuild epoxy primer. Started with 2 coats over the patch, then two more working out. Sand primer with 220
rolled and tipped first coat of sterling paint. Not really concerned with runs or sags at this paint, just trying to get some coverage.
Let first coat set up over night, sanded sags/lines out with 320 grit. Rolled and tipped a second coat.
It is not 100% though, I now have a bout 4 coats on the repair area and it shows that my coverage on the rest of the hull is thin (if you look hard at it). The repair area looks better that the rest of the side. So now, I have to put one continuous coat on the whole port side that might have to wait until I get a new motor though.
Old 10-18-2012, 08:09 AM
Good job!! I cut mine out and replaced at rebuild.
