Old 11-06-2012, 08:38 PM
Default 20 Master Angler Gunnel Supports
I'm planning on putting new gunnel supports/rod holders in the MA I've been working on. My question is, should I cut the supports so they fit flush with the outer hull or should I leave a gap? If flush, should they be epoxied to the outer hull. Not sure if the hull flexes to much for the joint to hold. I have searched for pics and it seems that some MA do not have visible supports and some do.
Old 11-06-2012, 10:39 PM
everybody everybody is offline
I did as your thinking. It gave the gunnels alot of support.
www.lionheartlandscapes.com Design, install, and concrete pavers. Will travel
Old 11-09-2012, 09:30 AM
Thanks, can you post a better pic? It looks like you boxed yours in. Do you have rod storage under the gunnells
Old 11-14-2012, 03:08 AM
kendalhelms kendalhelms is offline
No no don't cut I guess you should leave a gap it will better rather than cutting the support.
Super Second Salvaged Boat Auction for Sale only at auctions boats.
Old 11-14-2012, 09:34 PM
the outter hull I think would flex too much, I want to put some in but would leave a gap and attach top and bottom - I walk on mine as is
