Old 12-18-2012, 09:02 PM
Default Fairing
I'm using polyester resin to glass the console I modified. I bought some poly fair from Mertons and was wondering how you guys fair. Heavy first coat, sand then as many thin coats as needed to get it right. Or many thin coats sanded in between each coat. Thanks for the help.
Elijah
Old 12-18-2012, 09:13 PM
Got it...much like traders fairing issue a while ago, it needs a thick coat to cure properly.
Old 12-19-2012, 09:42 AM
bigeasy1 bigeasy1 is offline
I've had great results with Polyfair,no matter how thick or thin when applied.I used it to fair out extensive damage to the gunnels that the previous owner did,and used it on the rear cap that I cut off when I did the transom.
Never had any curing problems with the Polyfair,no matter the thickness.
Mixed it up on a piece of flexible cutting board material,and applied it where needed,thick or thin.I had better results applying it in thin coats,rather than a thick coat that had to be sanded down.
It doesn't like to be under catalyzed,so it's better to work with small batches,and apply it quickly.
The flexible cutting board mats from the dollar store work nice,any remaining cured waste on it comes right off when you flex the mat.Re use it over and over.
All this,just for a boat ride
Old 12-19-2012, 09:49 AM
Now I find this out! After cutting up hundreds of cardboard boxes and the project nearing completion.
Good tip.
Old 12-19-2012, 01:26 PM
that is a good tip!! I will definetly pick some up today. I bought just a quart of poly fair the other day to test and it and i used the whole thing and it came out great. so i just ordered another gallon of it today. thanks for the tip and your history on the product.
Elijah
Old 12-19-2012, 04:00 PM
bbh57 bbh57 is offline
I use paper plates.
Old 12-19-2012, 04:15 PM
This is how the poly fair came out on a part of my console after just 2 coats. Can't wait to get more and finish the console.
Old 12-19-2012, 04:35 PM
Looks like a sanding disc soldier who bit the dust! RIP
Old 12-19-2012, 08:27 PM
BigLew BigLew is offline
..or had a "dust-up"! Your choice.
(couldn't resist- my bad)
Plan accordingly!
Old 12-20-2012, 09:37 AM
Elijah
Watch for ups today.It shipped last night.
