Old 06-06-2013, 07:01 AM
Aquabart Aquabart is offline
Default 20sf prop recommendation
Hi all, I have to prop my 20sf and need some recommendations. I bought the boat with a blown 115 1986 Suzuki and have since re powered with a 1996 Yamaha pro v 150 with no prop. Any help would be greatly appreciated. Thanks!!!
Old 06-06-2013, 08:25 AM
I had a 150 evinrude 2 stroke had a 15p prop and hit about 35
http://www.youtube.com/watch?v=oREgh4QJzPs&feature=
82 seacraft 20SF
Bayview Canvas
Old 06-06-2013, 09:46 AM
bitsamonkey bitsamonkey is offline
A good starting point would be a factory Yamaha 19" prop. They're some kind of semi cleaver with good stern lift. Then, if you need to, you can have it re-pitched up or down ... probably down if anything.
Old 06-07-2013, 01:00 AM
never swing a 19 a 17 something
Old 06-07-2013, 09:36 AM
That motor has a 2:1 lower unit and will swing a 19. 5500 rpm, 19", 15% slip gives you 42 mph.
Old 06-07-2013, 05:19 PM
forgot about the 2:1 mine has a 1.87
Old 06-07-2013, 06:27 PM
Might want to edit your profile. I have 5 or 6 props. Where are you? Recently got a PT QSM and want to give her a spin.
Old 06-07-2013, 08:34 PM
Xanderman, PT QMS or MQS? What pitch? Are you stil running a jonnyrude? Is this for the racer or the Mighty slacker? Look forward to hearing your results.
Old 06-07-2013, 09:06 PM
Oooops. MQS 4 15p. Just rebuilt her carbs. I love my slacker. New bowls with the big kit which I should have done the first time... The old style alum. 3 deuces are far better than the Minlons. Anyone know if you can retrofit the old style on that reed plate? Plastic carbs cause pause. Fingertip pause please. Look at the coarse threads.
Not for the ham handed. Mmm ham. My pig has never sounded better. Wheee!
Ok Clifford you`re home.
Cheers,
Dead Lobstah. Hmm.
Old 06-08-2013, 11:39 PM
I'm in RI
