Old 12-06-2014, 06:29 PM
reedjsmith reedjsmith is offline
Default Need to add a transom drain plug
So I'm going through a full restoration on a 1975 20 CC. I just realized the shop forgot to add a transom drain plug. I need to drill a new one and was wondering if anyone has done this before and has recommendations on how to handle it. size, fitting, location etc.
Old 12-07-2014, 09:20 AM
Drill it at least 1/4" larger then back fill it with thicken resin then re drill it the correct size. This will give you a good sealed hole.
Old 12-07-2014, 09:43 AM
Same idea different twist--I also drilled oversized and used resin to set in a PC of a old fiberglass outrigger tube I had laying around
Old 12-07-2014, 02:18 PM
My Transom is poured do I still need to resin it?
Old 12-07-2014, 06:33 PM
I wouldn't think so. another advantage of a poured transom.
Old 12-07-2014, 06:43 PM
I installed a garboard drain plug assembly thru the bottom of the keel versus out the transom. Therefore, the bilge can be drained while on a lift or a trailer from within the boat without climbing underneath. This also helps maintain the integrity of the transom from water intrusion
Old 12-07-2014, 07:50 PM
ocuyler ocuyler is offline
I've seen this on Chuck's boat. If you have to drill a hole, this is the way to go. Especially if you forget to put the drain plug in when you launch, you don't have to put it back on the trailer and look stupid even though we all really enjoy that opportunity...
Otto
Old 12-20-2014, 09:13 AM
capt chuck were did you get your t handle? then was it just brazed on? I like that set up. my boat is lift kept also and I can not reach the drain plug to drain, this would solve that problem!
Old 12-20-2014, 12:13 PM
Perko Makes them. ----->http://www.pyacht.com/perko-garboard-drain-plugs.htm
Mine is custom S/S
Old 12-20-2014, 01:00 PM
Wow, that IS very nice!...Gucci class.
