Old 06-11-2015, 09:32 AM
shine shine is offline
Moderator
Default Transom/composite foam, honeycomb panels
We are now stocking transom composite material as well as pre-laminated honeycomb panels.
Transom boards are 3/4" thick, 26 lb density with fiberglass roving reinforcement.
General purpose FRP reinforced boards in 1/2" for decks, gunnels, stringers, etc.
http://http://www.gulfstreamcomposit...gory-s/136.htm
Fiberglass honeycomb panels are 25mm (bit over 1") and come pre-laminated with 17 oz of glass on each face. Ideal for decks/soles or frames.
http:// http://www.gulfstreamcomposi...gory-s/137.htm
Prices are better than anywhere else. Available for pickup or we can ship by freight.
Joel
Old 06-11-2015, 07:29 PM
[QUOTE=shine;236806]We are now stocking transom composite material as well as pre-laminated honeycomb panels.
Joel[/QUOTE
Hey Joel,
Congrats on the expansion of your line. I will be wanting some pre preg for a rear vertical panel. Non structural. 2`x7` maybe?
Cheers,
GFS
Old 06-12-2015, 08:19 AM
Moderator
Im sorry, but I dont have a good supplier for pre-pregs
Old 06-13-2015, 07:33 PM
Is there a minimum order on the sheets of foam?
Old 06-17-2015, 02:07 PM
Moderator
No minimum order on core materials, but freight is the same for 1 or 10 sheets.
Old 06-18-2015, 07:04 AM
Cool, may try out some of this stuff. I will get with you for a shipping quote to 28562 business address with unloading means.
Old 06-18-2015, 09:34 AM
Moderator
Attachment 10604
$95 for up to 100 pounds
if over 100 pounds (more than a couple sheets) $175 if we need a liftgate on your end (if no forklift)
the honeycomb panels dont ad much weight at all
Old 06-18-2015, 04:23 PM
Sweet! That's a good rate on the shipping. We do have a fork lift so no issue there. We get 2-3 freight trucks here daily and there is always some one here to unload 24-7. Look forward to getting some soon
