Old 06-05-2016, 08:50 PM
Finnatic Finnatic is offline
Default A few questions
Hello all it's been a while that I've posted anything and have a few questions. I have a project boat to do with my son. It's a 1972 206 CC. I've had the boat for 3 years now and have it completely striped down ready for the nasty work. I'm freeing up some time these days and want to remove the entire deck and transom. I want to raise the deck to make it self bail also want to raise the transom to accommodate the newer 25" shaft motors. Is 4 inches enough to raise the deck to install scuppers ? Also is 5 inches the amount needed to raise the transom, it's my understanding they ran motors with a 20 inch shaft back in the day. Thanks in advance.
Old 06-05-2016, 08:53 PM
72 should be 19' 6"
Raise deck 2 inches
Raise transom 5 inches
Case closed !
Good luck, have fun...
Old 06-05-2016, 09:00 PM
72 should be 19' 6"
Raise deck 2 inches
Case closed !
Thanks NoBones, I didn't thing 2" would be enough, I'm sure you guys know. Not sure about 19'6" the registration states 20'6" as did the last owner.
Old 06-05-2016, 09:12 PM
72 should be 19' 6"
Raise deck 2 inches
Case closed !
Lightstream
Old 06-05-2016, 10:02 PM
Default Questionnaire -
2" will probably be fine if you are powering with 140 HP or less 4 S or 150 HP or less 2 S. The 20' boats were designed for 75-115 HP 2 S's - they do fine with a 115. What motor are you planning to hang on it and what do you use the boat for? What is your typical load and your typical daily run?
We need to develop a check off list like -
I. Boat length (please check one) -
1) 15' Scampi
2) 19' Bowrider
3) 20' CC
4) 20' Seafari
5) 23 CC
6) 23 Sceptre/Tsunami
7) 25 SeaFari
8) 27 Seamaster
9) 27 Raceboat
II. Power (please check one)
1) 75- 90 hp 2S / 4S
2) 100-115 hp 2S / 4S
3) 130-150 hp 2S / 4S
4) 150-225 hp 2S
5) 150 - 200 hp 4S
6) 225 - 300 hp 2S
7) 225 - 300 hp 4S
8) Twins - please specify________
9) 240 Bridgeport
10) Rolls-Merlin Go-Devil
11) Quad Bearcats
III. Typical Load / Windage -
1) Tee Top
2) Tee top with electronics box
3) Hardtop
4) Tower
5) Bikini tops - yes / no
6) Fishing gear
7) Dive gear
8) Beer (rounded off to the nearest case)
9) Persons(*) on board
(*) including mother-in-laws
IV. Boat use -
1) Fishing
2) Diving
3) Cocktail cruiser
4) Camping / Cruising
5) Racing
6) Sandbar Party Classic Chick Magnet
7) Tax write off through shell company (i.e. "Trolling Gear Research,
Assessment and Analysis LLC.")
The answer to these questions will help us here at Classic Seacraft provide the best suggestions and route for your well planned endeavors to resurrect the this Classic.
Old 06-06-2016, 12:32 AM
1) 15' Scampi
2) 19' Bowrider
3) 20' CC
4) 20' Seafari
5) 23 CC
7) 25 SeaFari
8) 27 Seamaster
9) 27 Raceboat
4) 150-225 hp 2S
5) 150 - 200 hp 4S
6) 225 - 300 hp 2S
7) 225 - 300 hp 4S
9) 240 Bridgeport
11) Quad Bearcats
1) Tee Top
3) Hardtop
4) Tower
6) Fishing gear
7) Dive gear
IV. Boat use -
1) Fishing
2) Diving
3) Cocktail cruiser
5) Racing
Jiminy Christmas Marshtackie......
Did you start early today with the buy one get one..
AKA: BOGO
I know Walgreens was running a special, but jeesh...
You made me half looped just tryin' to read your response..
Old 06-06-2016, 05:44 PM
Default Complete Data, Please
"Just the facts Ma'am",
Signed, Joe Friday
Old 06-06-2016, 09:52 PM
Do yourself a favor and raise the transom to 27 inches. 25" shaft will still fit. Wish I made mine that height. If for some reason when you hang the motor you find its two high just trim it down. My suzuki140 is as high as I can get it and it could probably go up another hole if I had the room to do it.
Old 06-07-2016, 12:30 PM
1) 15' Scampi
2) 19' Bowrider
3) 20' CC
4) 20' Seafari
5) 23 CC
7) 25 SeaFari
8) 27 Seamaster
9) 27 Raceboat
Do you have something against the "Original" 21'
Old 06-07-2016, 02:24 PM
T-3 is very old and forgetful. I started taking Prevagen, you know the stuff made with jellyfish - Now all it think about is Plankton!!
My apologies T-1
Finnatic says he has a 20"-6', maybe it's really one of the of the last 21's. (Well, other than that one we know is in the basement of the CIA)
