Old 01-26-2017, 09:13 PM
Default Side Scuppers
I'm closing in my transom when permanently mounting my bracket and forgoing transom scuppers and will be draining out the sides? Has anyone seen or come across some molded clam covers designed for side drains? I really don't like the looks of the stainless screw on type.
Old 01-26-2017, 09:42 PM
cdavisdb cdavisdb is offline
Have not. The only thing I've seen is a bronse cover that is held to the hull with screws. It would work, but it ain't pretty.
Why have clam covers at all? My 25 has straight out holes through the side, seems to work fine. Even when the boat is rolling, not much water comes back in. One thing that might be important. Mine has a small well to catch water coming off the deck or in thru the hull
Old 01-27-2017, 08:05 AM
Do you have any issue with back spray in a banking turn? I'm concerned somewhat as I want the hole to be elongated with the bottom level with the deck so fish guts can run out easily. After seeing how well they work on a commercial boat there is no way I'm going thru the transom again.
Old 01-27-2017, 09:52 AM
HeadHunter HeadHunter is offline
Would be very easy to make your own.
Old 01-30-2017, 01:34 PM
Just laid some up the other day! Sorry no installed pics yet, just the quickie mold..
Untitled by dirtwheelsfl, on Flickr
Old 01-30-2017, 04:47 PM
martin martin is offline
Todd Jones has side scuppers on his boat.. they are molded fiberglass if I recall. Lookup Capttodd on here I think I posted some pics of his boat.. I like them but the draw back that I could see was backing down.. I always keep my stern to to wind.. it's easier for me to hold up on a wreck... But that is just me.. his are about 8-10" long... Use a piece of PVC and wrap it in glass then cut off or make a mold out of PVC built a 1 piece with flanges that are glassed in.. but what ever the case
I would make flaps to keep water out...
Old 01-30-2017, 04:52 PM
Default Side scuppers
CaptTodds
Old 01-30-2017, 09:48 PM
Can't say as I ever looked at the scuppers in a turn, or, for that matter, when the boat was rolling a lot. Never noticed any extra water back there except when I had a lot of people weight on one side in the stern for an extended period.
I think the small well under the scuppers is important. I get a small amt of water flushing in and out regularly. It quickly flushes any fish guts or other stuff out of the boat, no fuss, no muss, and the flush doesn't extend beyond the well.
Old 01-30-2017, 10:47 PM
FAS FAS is offline
there is a couple good ideas here,I would say mold your own and feather them in..otherwise,without scoops you will get a gurgling effect when coming up to plane
Old 01-31-2017, 11:15 AM
shrek shrek is offline
How high do you have to raise the floor to run side scuppers without having them under water at rest?
