Old 06-16-2017, 08:14 PM
jwclbi jwclbi is offline
Default picked up this little rig
Just found this little whaler for a good number, only trouble is previous owner got varnish all over the deck/etc. Anyone know what will take it off with damaging gelcoat?
Old 06-16-2017, 09:07 PM
I've used fiberglass paint striper with some success but you can't walk off and leave it for long. Left on too long and it will soften the gelcoat. It's not as agressive as regular striper but it can do damage if you don't watch it.
Rod
Old 06-17-2017, 05:12 PM
Ok thanks for the help! Ill check into that, thank you!
Old 06-17-2017, 07:13 PM
A magic eraser will help, but it is really a 1000- 2000 abrasive, so be careful.
Don't burn through the thin gel.
Old 06-17-2017, 07:51 PM
bobbert bobbert is offline
Try lacquer thinner. Small spot first it should work.
