Old 08-01-2017, 04:25 PM
dginge dginge is offline
Default 1984 23cc
Is 1984 a good or bad year? Have my eyes on one. My 1977 was a tank. Someone refresh my memory. Thanks
Old 08-01-2017, 04:38 PM
Remember the 1978 PintoStang.... well, not that bad. I believe it is an SCI hull. There is talk of some select hulls coming out of the mold with a hook but I am not that knowledgeable as some of the vets here who should be piping in shortly to give you all the details.
Old 08-01-2017, 05:25 PM
Thanks. Keep em coming
Old 08-02-2017, 10:56 AM
There was one 23 mold that SeaCraft Industries inherited when they bought Potter's bankrupt company that had with a slight hook in it on the center panel on port side just forward of transom. Potter warned them not to use it but they apparently did on at least one 23 Sceptre I looked at. (See pic below.) It's probably less than 1/8" deep and could be easily fixed, but it's something I'd check for on any SCI hull.
Old 08-02-2017, 12:15 PM
Thanks so much. Very cool.
Old 08-04-2017, 10:11 PM
Chrismacholz Chrismacholz is offline
I have a 1987 and it's a fantastic boat. If you can get past the stigma that it's not a Potter you will enjoy it. People tend to over analyze this stuff - I know I did when I was shopping around. I prefer the layout of the post-potter hulls anyway. The transom is much cleaner and you have a bigger cockpit because of it. These later boats also have bigger gas tanks and better scupper layout.
Old 08-04-2017, 10:23 PM
Would that minor amount of dimensional difference really make a noticeable performance difference? What is the net result in the ride?
Old 08-05-2017, 06:15 AM
Yes it will but the fix is so easy it's not worth considering as a disqualifier.
Old 08-05-2017, 06:27 AM
I agree, I would have no issue going with an SCI hull. some say Potters are built like tanks but is there any real evidence of that? Maybe, but that isn't always a good thing if more glass was used beyond what was structurally needed. I can also tell you Potter hulls aren't perfect. When you dig as deep as I have into then you will certainly find shortcomings in certain areas of construction.
Old 08-05-2017, 11:16 AM
I totally agree with Kmoose and the above statement. On my 78 Potter 18 I had to replace the bow eye last year. When I finally got an access hole cut in the liner I found out that the glass was over 1/2" thick in the bow. In general our 18 is a very heavy boat. That being said though I will definitely take one that's too heavy over one that's too light any day of the week.
Rod
