Old 07-20-2018, 08:43 PM
Default Battery Cable - wire size?
I'm installing a battery switch and need to run cable for 6'. What gauge wire should I use? This will be for a starting battery for a V-6 Outboard. Any thoughts? I was thinking #2 or #4.
Thanks,
Jim
Old 07-20-2018, 08:57 PM
FLexpat FLexpat is offline
Use the voltage drop calculator listed here: http://www.marinewireandcable.com/20...lculation.html
Old 07-20-2018, 09:35 PM
Jim, for 6' the #4 is good, easy. If it's for the mighty 225 Excel go with #0 welding cable, it's a bad engine!!!
Old 07-20-2018, 09:41 PM
erebus erebus is offline
Heres the wire size calculator I use all the time.
Need to know the max amps you'll be drawing though.
http://circuitwizard.bluesea.com/
2 gauge wire going 6 feet is good for up to 200 amps.
Zachary
