Old 12-24-2018, 04:25 PM
bbh57 bbh57 is offline
Default Problem with my Suzuki
Im having problems with my DF 250. The IAC valve keeps going bad. Motor will start at the dock run fine to where-ever Im going then when I slow down to stop the motor quits. It then will only start with throttle advanced in neutral, it runs fine, then when I attempt to take out of neutral and put into gear it quits.
First time it happened I replaced IAC and had no problems for about 3 months of once or twice a week use. just went out again...
I've read online of others having the same problem on their Suzuki's but have not found a fix.
Been towed in twice, Im over it!
