Old 08-17-2019, 10:42 AM
Redfish27 Redfish27 is offline
Default Question about leaning post installation
I'm getting ready to swap out the original bench seat on my 1978 20' SF with a leaning post and wanted recommendations on the distance between the leaning post cushion to the console and steering wheel. Thanks for the information
Old 08-18-2019, 03:29 PM
Bigsean Bigsean is offline
I believe the standard is 18" bet the helm and base of the leaning post..most helm pads that are sold are 16" wide..just to give you a idea but you can put wherever you feel comfortable!
Old 08-18-2019, 07:19 PM
caper caper is offline
I like mine really close - easier to steer sitting on the post
Old 08-19-2019, 06:39 AM
mine is 14"
Old 08-19-2019, 10:26 AM
One thing you may want to check is crowned deck vs. flat LP feet. Birdsall tweaked mine to match.
Old 08-19-2019, 12:43 PM
So, somewhere between 14 and 18 inches? Why would you not put it to where it is comfortable for you.
Old 08-20-2019, 06:54 AM
mine is 14"
I placed my leaning post in and propped my butt on it, stood in front and leaned on it and it ended up being 14". Your posture and tummy will play a part.
Old 08-20-2019, 07:48 AM
It’s definitely a balancing act when you stand up you needed little further back when you sit down it’s hard to reach but I must’ve ended up at 16 inches because the pad I got from capt Harry’s just fit
Old 08-20-2019, 12:06 PM
Don't put too close you have to consider when your running with you knees up on the foot rest and you hit a wave wrong..you don't want your knees all jammed up..JMO
Old 08-22-2019, 11:42 AM
Thanks everyone for all your input and recommendations. Completed the install and worked out perfect
