Old 08-19-2020, 03:45 PM
Walter Sobchak Walter Sobchak is offline
Default Seacraft 20 performance help
I have a new to me 1972 20SF with an armstrong bracket and a 2016 F150 hanging on the back. Now, I've been doing a lot of reading and realize these boats were meant for 300 lb motors hanging off the transom and they like perfect balance. But I need to work with what I have. I only have room to raise the motor one more hole. The cav plate is 4.5" above the keel. Speed wise, I am fine with what I'm getting, but ride is where I'm not satisfied. Current prop is a quicksilver thunderbolt 15.3x19P. WOT motor is turning 5400 RPM with a speed of 44 MPH.
Presently, I have a few issues:
1. Hole shot - Bow rise is substantial. Like I lose sight of whats in front of me. It stays that way until the boat finally jumps on plane which seems to me to take too long. I have not timed it.
2. Once on plane, any amount of trim makes the boat porpoise. If I keep the motor tucked, it rides great. Very little or no tab necessary.
Next time I'm able to get the boat out, I plan to check cav plate height while running and time how long it takes to jump up on plane.
I have spoken to Ken at Prop Gods and he has recommended a Powertech SFS4 in 17 pitch. When asked about the mercury rev4 he stated that it was a lot of prop for an F150 and doesn't have as much stern lift.
Any other thoughts or ideas? I was thinking about adding some lead ballast bags to the anchor locker to try and balance the boat further. Thoughts?
Thanks for your help.
PS - I know there is a performance forum but figured I would get more traffic in the general forum.
Old 08-19-2020, 04:36 PM
I forgot to add, the previous owner put a 30" setback bracket on it.
Old 08-19-2020, 09:21 PM
Do you have a Dolfin? Trim tabs? Motor height is very important.
Do your best not to add ballast. Shift weight (Batteries, coolers).
The Dude abides
Lloyd
Old 08-19-2020, 11:20 PM
https://www.hydro-shield.com/
This will be a great help.
Properly set up it provides stern-lift at all speeds without forcing your bow down. It's a hydrofoil that stays in the water. You can adjust trim without instantly looking like Flipper begging for a snack!
I ran one on my outboard 20' Seafari, both with the XR4 motor and later with the 90 Optimax. I just purchased one for my 18" Superfisherman with a 90 Etec.
Old 08-20-2020, 06:55 AM
The PT 4 blade should get you real close. Ken's suggestions for me (3 times) have been spot on!
Old 08-20-2020, 09:22 AM
lelandtampa lelandtampa is offline
Great screen name.
Old 08-20-2020, 11:10 AM
I'd love to see pics of the boat. I'm heavily considering enclosing my 20sf with an Armstrong but get nervous every time I hear stories like yours.
Old 08-20-2020, 02:10 PM
Old 08-20-2020, 02:37 PM
Beautiful boat! Registered in SC?
Vezo.
Old 08-20-2020, 04:57 PM
Vezo.
Yes, sir.
