What measurements are you looking for?
hi hermco thanks for the reply. the bracket i am thinking off will be 24inch wide with a 24inch setback from looking at the brackets on here that the likes off outhers on here have made it looks thay slant from the transom to transom what is that slant allso how deep is the v in the bottom.... i understand that when fitting it needs to be set 2 inch above the bottom of the keel is the 1inch per foot off setback on top off that for the engine end i am allso thinking off haveing a 4x3 chanel across the inside of the transom top and bottom to reinforce the transom and act as a spreader for the bracket a.t.b dave
You can build the bracket with any shape. It will not be in the water when the boat is on plane. The larger the area that is submerged at rest will determine how much displacement or floatation it will provide if that is an issue. The first bracket designs were just welded tubing and a plate to mount the motor.
![]() Quote:
You can design it any way you see fit. The end result is the transom at 24" setback should be at least 27" up from the keel.
hi thanks for the reply that makes it clear a.t.b dave
That is assuming you are using a 25" shaft length outboard. I should have specified that.
![]() Quote:
![]() Quote:
![]() Quote:
You can use plywood and glass construction if you like, but you really should use epoxy resin if you go that route. If you use strick's one-off mould method, you can use less expensive polyester resin, you'll have much less fairing to make it look professionally done, and it will be lighter and stronger. The method is tried and true, whereas the plywood/glass approach is a reinvention of the wheel unless you have a professionally designed solution. Dave
Blue Heron Boat Works Reinventing the wheel, one spoke at a time. |
